Public Release - 1.02
by Iroh
Follow this guide to remove and replace the LPCAMM2 memory (aka RAM) in your Framework Laptop 13 Pro (Intel® Core™ Ultra Series 3).
Framework Laptop 13 Pro (Intel® Core™ Ultra Series 3) supports one slot of LPCAMM2 memory up to 96GB. For further details, please see our "What DRAM/memory is supported by Framework Laptop 13 Pro (Intel® Core™ Ultra Series 3)?" Knowledgebase page.
No parts specified.
  2. Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover. Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover.
  3. Flip over your laptop and open it. Use your fingers to lift the Input Cover up and release it from its magnets.
    • Flip over your laptop and open it.
    • If you're having trouble lifting the Input Cover, you can leverage the gap at the bottom right corner to get your fingers fully under it.
  4. Flip the top of the Input Cover so the Keyboard is facing down. Rest the Input Cover over the Battery, making sure the Touchpad Cable isn't being strained.
    • Flip the top of the Input Cover so the Keyboard is facing down.
  5. Insert your finger into the Touchpad Cable press connector loop. Lift up to disconnect the Touchpad Cable from the Mainboard.
  6. Remove the Input Cover. Remove the Input Cover.
    • Remove the Input Cover.
  7. Use your Framework Screwdriver to loosen the captive T5 Torx screws securing the LPCAMM2 Memory Cover in reverse order from 3–1. Use your Framework Screwdriver to loosen the captive T5 Torx screws securing the LPCAMM2 Memory Cover in reverse order from 3–1.
    • Use your Framework Screwdriver to loosen the captive T5 Torx screws securing the LPCAMM2 Memory Cover in reverse order from 3–1.
  8. Lift the LPCAMM2 Memory Cover straight off the memory and remove it. Lift the LPCAMM2 Memory Cover straight off the memory and remove it.
    • Lift the LPCAMM2 Memory Cover straight off the memory and remove it.
  9. Grip the LPCAMM2 module by its edges and lift it straight off its alignment pegs to remove it. Avoid touching the Interposer below the module. If the Interposer accidentally shifts, grab it by its edges to place it back into its alignment pegs.
    • Grip the LPCAMM2 module by its edges and lift it straight off its alignment pegs to remove it.
    • Avoid touching the Interposer below the module. If the Interposer accidentally shifts, grab it by its edges to place it back into its alignment pegs.
    • Make sure there's no dust or debris on top of the Interposer before continuing.
  10. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  11. Place the LPCAMM2 module on top of the Interposer, making sure it slots into its alignment pegs. Place the LPCAMM2 module on top of the Interposer, making sure it slots into its alignment pegs. Place the LPCAMM2 module on top of the Interposer, making sure it slots into its alignment pegs.
    • Place the LPCAMM2 module on top of the Interposer, making sure it slots into its alignment pegs.
  12. Place the LPCAMM2 Memory Cover on top of the memory, making sure its screws align with the screw holes. The cover should lay flat when aligned properly.
    • Place the LPCAMM2 Memory Cover on top of the memory, making sure its screws align with the screw holes.
    • The cover should lay flat when aligned properly.
  13. Use your Framework Screwdriver to tighten the captive T5 Torx screws securing the LPCAMM2 Memory Cover in order from 1–3. Make sure the screws are snug enough to create proper contact between the memory and the Mainboard.
    • Use your Framework Screwdriver to tighten the captive T5 Torx screws securing the LPCAMM2 Memory Cover in order from 1–3.
    • Make sure the screws are snug enough to create proper contact between the memory and the Mainboard.
  14. Position the Input Cover, Keyboard down, on top of the laptop so it just covers the Battery. This allows the Touchpad Cable to be folded over and reconnected without straining it.
    • Position the Input Cover, Keyboard down, on top of the laptop so it just covers the Battery.
  15. Insert your finger into the Touchpad Cable press connector loop. Align the press connector over its socket and press down with your finger.
    • You should hear it "click" into place. If you're having trouble, reposition it and try again. Don't try to force the connector into place.
  16. Flip the Input Cover over the laptop and align the bottom edges. Flip the Input Cover over the laptop and align the bottom edges.
    • Flip the Input Cover over the laptop and align the bottom edges.
  17. Lay the Input Cover over the laptop and let the magnets snap it into place. The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws. The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws.
    • The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws.
  18. Close the laptop and flip it over.
  19. Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover. Don't overtighten the screws—just make sure they're snug.
You finished fixing your Framework Laptop! The first boot will take longer and start with a “Memory Training in Progress” screen. If you run into any errors during Memory Training, please see this page.
Iroh
112 Guides authored
236 Guides authored
Past 30 Days: 1
All Time: 31
