added note on packaging variation
by Sandy Qualey-Dobson
No parts specified.
  1. The first step is to open the box and identify the contents, the exact contents will vary depending on how you configured your Laptop, but inside the box you will find: Bezel Input Cover
    • The first step is to open the box and identify the contents, the exact contents will vary depending on how you configured your Laptop, but inside the box you will find:
    • Bezel
    • Input Cover
    • Framework Laptop 13
    • Power Adapter
    • Expansion Cards
    • Storage, Memory, any additional Expansion Cards and importantly the Framework Screwdriver!
    • Note that depending on the retail packaging for Memory , this may be located underneath the Power Adapter instead.
  2. Start by unpacking the box containing your Framework Screwdriver, Memory and Storage, these are all together in the box found underneath the Laptop.
    • Start by unpacking the box containing your Framework Screwdriver, Memory and Storage, these are all together in the box found underneath the Laptop.
    • You may also want to remove the Expansion Cards from their boxes at this stage too!
  3. Open the Laptop as pictured and you will find a clear protective cover as pictured, this can simply be lifted off and set aside.
    • Open the Laptop as pictured and you will find a clear protective cover as pictured, this can simply be lifted off and set aside.
    • This protective cover is made of post-consumer recycled PET and is highly recyclable. We recommend this can be disposed of with other household plastic recycling.
Sandy Qualey-Dobson
45 Guides authored
227 Guides authored
Past 30 Days: 1
All Time: 67
