Disconnect the Display Cable (PR) - FL13
by Iroh
  1. Find the black Display Cable that connects the display to the mainboard. Unplug the cable by pulling it directly upwards using the black pull tab. Carefully lift up the silver grounding tape that is holding the Display Cable to the hinge.
    • Find the black Display Cable that connects the display to the mainboard. Unplug the cable by pulling it directly upwards using the black pull tab.
    • Carefully lift up the silver grounding tape that is holding the Display Cable to the hinge.
    • Free the Display Cable from the Bottom Cover and carefully remove it from any routing pegs. It will remain connected to the display.
Finish Line
Iroh
62 Guides authored
9 Members
169 Guides authored
Past 30 Days: 2
All Time: 30
