Asset Updates
by Iroh
    • Pre-rotate the new Hinges to a 90 degree angle to make them easier to install.
    • Place the left and right Hinges into the Top Cover and fasten them into place with the three fasteners each that you previously removed.
    • Carefully place the Top Cover assembly with the Hinges installed onto the Bottom Cover assembly and fasten the left and right Hinges into the Bottom Cover using two fasteners each that you previously removed.
    • Stick the antenna cables down onto the new Hinge.
    • Route the antenna cables through the hinge area, with the white and black cables sitting flat against the bottom of the Bottom Cover as much as possible. Avoid letting the cables twist or overlap, as this will interfere with the Input Cover and power button. You can use the spudger end of the Framework Screwdriver to help push the cables.
    • Route the antenna cables through each of the channels and rubber brackets.
Finish Line
Sandy Qualey-Dobson
47 Guides authored
194 Guides authored
Past 30 Days: 1
All Time: 20
