Asset Updates
by Iroh
    • Make sure that both the black and white WiFi Antenna cables are connected to the module and are rotated downwards as indicated in the second picture with the blue arrows.
    • Insert the WiFi module into the Mainbord by aligning the notch on the module with the notch on the socket.
    • Once the module is properly inserted into the Mainboard, carefully route both the black and white WiFi Antenna cables into the black rubber routers as indicated in the first image. Place both the cables behind the metal structure located near the top right of the WiFi module as well.
    • Important: The WiFi Antenna cables should not touch the Speaker located below the module as indicated in image one.
    • Place the silver bracket over the WiFi module and place the fastener in the hole. Using the T5 bit in the Framework Screwdriver, screw the fastener into place.
    • If you are using the new plastic WiFi bracket (shown in the third image) the bracket is attached to the card and contains its own fastener for easier installation.
Finish Line
Sandy Qualey-Dobson
47 Guides authored
194 Guides authored
Past 30 Days: 3
All Time: 37
