Title Update
by Iroh
This guide takes you step by step through the process of removing an Expansion Bay Shell and installing a Graphics Module. If you have already removed the module in your Expansion Bay, you can skip to step 11.
No parts specified.
    • Before beginning, make sure to shut down your Framework Laptop.
    • If the system is still powered on, you will see the chassis intrusion lights flashing red and blue when the Touchpad and Input Modules are removed.
    • In order to remove the Input Modules from the Framework Laptop 16, begin by opening the Input Deck Latches on each side of the Laptop.
    • When the latches are open you can see the red printed on the latch.
    Perhaps a dumb question, but what are the initial conditions? i.e. Should my laptop be powered off, but still plugged in, before starting this?
    Jonathan P Cox - Resolved on Release Reply
    As far as I know, Framework recommends powering off the laptop before opening it. As far as keeping it plugged in, I would not recommend that as it may be an electrical hazard.
    Soni -
    • To remove the Touchpad Spacers, slide them down and then they will lift away easily.
    • If there is resistance, make sure that the Input Deck Latches are open (see previous step).
    • After removing the Spacers, the Touchpad module can be removed in the same way. Gently slide it downwards from both sides and then lift away as shown.
    • To remove the Keyboard lift from the bottom using the pull tabs, and once lifted up the Keyboard module should lift out without resistance.
    • If your pull tabs are no longer attached, you can carefully use the spudger side of the Framework Screwdriver to lift the module away.
    • Remove your Input Modules or Spacers in the same way as the Keyboard, lifting from the bottom using the pull tabs as shown.
    You will need to remove the module from the Expansion Bay to later remove the Ventilation Plate in step 10, which instructions are missing from this guide. Refer to the "Install Expansion Shell" and "Install Graphics Module (dGPU)" guides for instructions on removing the module from the Expansion Bay. It is better to remove the module from the Expansion Bay now, as the guides require you to close your laptop, and it is better done when the mid-plate is still installed and fastened, than when the screws are loose, or the mid-plate removed, IMHO.
    Ádám Juhász - Open Reply
    IMPORTANT: This comment meant for the Fingerprint Reader guide ONLY. I didn't realize at the time, that leaving a comment for a step appears across ALL GUIDES WITH THE SAME STEP.
    Ádám Juhász -
    • Remember to power off the system and unplug the USB-C power cable before you open the Interposer Door.
    • You can access the Interposer and change the Expansion Bay Module without removing the Mid Plate.
    • Flip open the Interposer Door using the pull tab provided.
    • Make sure that the door is closed again before closing the Laptop lid to avoid any risk of damage to the display.
    • Loosen the 3 captive fasteners, and then use the pull tab to lift the Expansion Bay Shell Interposer out. These are captive fasteners, meaning that they will stay attached to the Interposer.
    • The Interposer should lift out easily. If you feel any resistance, check that all 3 fasteners are loosened, and do not force it.
    The new interposer design appears to have 4 screws instead of 3. If yours has 4 you'll obviously need to loosen all of them. 2 of them may be behind/under the flap in the middle that is used to pull the interposer out.
    Dave - Resolved on Release Reply
    • Loosen the two captive fasteners that secure the Expansion Bay Shell.
    • Note that these fasteners are captive and will remain attached to the bracket.
    • With the Interposer installed, close the Interposer Door.
    • With the Framework Laptop 16 closed, turn the Laptop over and gently slide the Expansion Bay Shell up from the Expansion Bay slot as shown to remove it.
    • If the Expansion Bay Shell seems stuck do not force it. Make sure that the captive fasteners are correctly loosened (see previous steps).
    • With the Framework Laptop 16 closed, line up the Graphics Module with the Expansion Bay slot and gently slide it into place.
    • You should hear the module click into place when fully inserted.
    • There should be very little resistance when installing the Graphics Module. If it is not sliding into place, do not force it. Remove the module and check that it is lined up correctly before trying again.
    • Tighten the 2 captive fasteners to secure the Graphics Module in place.
    • Lower the Graphics Module Interposer into place, noting the orientation as shown.
    • Tighten the 4 captive fasteners to secure the Interposer.
    • Be careful not to overtighten fasteners here. This step does not require excessive force.
    The interposer tolerances are extremely narrow. If the interposer doesn't line up properly, go back to step 14 and adjust the position of the graphics module so the interposer is properly aligned.
    You can verify it's properly connected on Linux via lspci | grep 7700.
    Chris - Resolved on Release Reply
    I had to start by tightening the connectors in back (closer to the display) first. In my case, tightening the front connectors first would not allow the rear ones to bite.
    When tightening I found it helpful to tighten each screw a bit at a time, and then switch to another screw, and repeat as necessary. Tightening one all the way down by itself made it hard to mate all four connectors.
    After my first attempt I received a boot message indicating that there was no expansion card installed and had to return to this step to ensure all the connections were tight enough to make proper contact.
    I’m confused. My interposer does not look like that. I only have 3 screws (2 in the back and one in front).
    Ice21 - Resolved on Release Reply
    If you tried, like i did, to mount the original interposer (the one from the expansion bay shell, not the graphics module) then it would have 3 screws and not fit. Use the graphics card interposer which does have 4 screws.
    Tom Bulsink -
    i struggled at first to get the back left screw to tighten. after a closer look i notice the threads have blue lock tight /thread lock.
    after scrapping carefully with my fingernail and trying again it finally tightened down.
    Bruce Hood - Resolved on Release Reply
    Comments added to Step 10 are appearing under Step 16. This comment was added to Step 10, but it appear under Step 16.
    Paul Wilson - Open Reply
    "With the Interposer installed, close the Interposer Door." Did you mean with the interposer UNinstalled / REMOVED?
    Msprg - Open Reply
    If step 10 and 16 are shared under the hood, then the text should not mention the state of the interposer (installed or not) at all.
    Furthermore, I can comment on step 10, but have no comments, and when commenting on step 16, no text area appears, but comments appear in the context of step 10 instead of 16.
    Should this read "With the Interposer removed, close the Interposer Door" instead of "With the Interposer installed..."?
    Paul Wilson - Resolved on Release Reply
    Should read "With the Interposer removed, close the Interposer Door.
    Jack C - Resolved on Release Reply
    • Please see our guide here on possible Input Module configurations.
    • Holding from the pull tabs at the bottom of the Keyboard module, line it up with the dashed guide lines printed on the Mid Plate. Note that you can align a Keyboard so that it is either along the left edge, the right edge, or centered. With the Keyboard held at a 20 degree angle, slide it up into place.
    • The notches along the top of the Keyboard will fit into the corresponding alignment guides under the Ventilation Plate.
    • Lower the Keyboard gently into place, it should snap in place magnetically and sit flat.
    • Ensure that the pins in the Mid Plate to the left and right of the Input Module Connector align into the corresponding holes in the Keyboard module.
    • Next install, two Spacer Modules, an LED Matrix, a Numpad, an RGB Macropad, or whichever other combination of two Small or one Medium sized Input Module you have.
    • Slide these in at an angle and lower into place, the same way the Keyboard was installed.
    • Whichever Input modules you chose to install, you should have no empty spaces in the top row before proceeding to the next step.
    Looks like steps 24 and 25 are reversed
    Richard Ciavarra - Resolved on Release Reply
    • Place the Touchpad Module flat, slightly below the Keyboard as shown.
    • Like the Keyboard, you can confirm it is properly aligned by lining it up to the dashed lines on the Mid Plate.
    • Applying gentle downward pressure to keep the Touchpad module flat, slide it up into place.
    • Remember that the Input Deck Latches should still be open at this point, otherwise the Touchpad Module won't slide on.
    • The Touchpad Module can be installed either directly below the Keyboard or offset by one space to the right. For example, the Keyboard can have the Touchpad below it, or the Keyboard can be left-aligned while the Touchpad is centered.
    I had to gently push down the keyboard module for the touchpad to correctly slide up to meet it.
    Will Stott - Open Reply
    I had issues getting the touchpad module to slide all the way up so it was flush with it's spacers. What I figured out was gently place your hands flat on each side and give even downward pressure while sliding the touchpad module latterly up to the keyboard and this got it flush with the touchpad spacers.
    Dan Wehner - Resolved on Release Reply
    I need help the mouse pad is not working and setting this laptop I have to use the keyboard /:
    Cephas - Resolved on Release Reply
    I am experiencing a significant edge between the touchpad module and spacers. I realize the touchpad should be sitting above the keyboard, but the upper corners of the touchpad module sit sharp up above the spacers. Has anyone experienced this? Any solutions to get the plates to sit flush?
    I tried removing the keyboard, and the upper corners of the touchpad module sit slightly lower, but still are not flush with the spacers.
    Michael - Resolved on Release Reply
    I think so. Happens with the Touch Modules Spacers too. A bit unsatisfying, but I can live with it.
    Matias Fernandez - Resolved on Release Reply
    This is replying to the comment by @crippledlord. For some reason it does not let me delete it.
    Matias Fernandez -
    I tried to get "Keyboard... left-aligned while the Touchpad .. centered.” (with numpad on right) but this wouldn't work. I also didn't read the "The Touchpad Module can be installed either directly below the Keyboard..." note too clearly... I think it should have a warning similar to the fasteners. I went down a rabbit hole of troubleshooting. I used Possible Input Module combinations on Framework Laptop 16 and later My touchpad isn't working because I inadvertently triggered a device issue during my troubleshooting requiring the "disable/enable the touchpad in Device Manager" process.
    Trevor Textor - Resolved on Release Reply
    @crippledlord Same here. I tried multiple times to get the touchpad module flush but it always ends up just a tad above the keyboard. Everything else is flush. Could be better but not something hinders the use.
    Fisherman - Resolved on Release Reply
    I think the same goes to the right. I wanted the keys modules to the left and track all the way to the right. I can only get one space over.
    Raju Rayavarapu - Resolved on Release Reply
    It appears that the trackpad module can not be mounted any further left than the keyboard. i.e I wanted the keyboard all the way to the right and the num pad all the way to the left, but the track pad won't fit anywhere other than directly below the keyboard module.
    Should the edge of the edge of the touchpad module stick above the keyboard slightly? It's not sharp, but is noticable.
    Tonyromo1988 - Resolved on Release Reply
    @crippledlord I think so. Happens with the Touch Modules Spacers too. A bit unsatisfying, but I can live with it.
    Matias Fernandez -
    • Just like installing the Touchpad module, place the Touchpad Spacers flat on the Input Deck, slightly below the Keyboard or Spacers above.
    • Applying gentle pressure, slide the Touch Module Spacers into place.
    • With the Touchpad Module Spacers installed there should now be no empty spaces on the Input Deck.
    The touchpad CAN be placed and work in other positions beside the middle, you can place it on the left or even on the right if you have the keyboard centered, you can see all the possible combinations here Possible Input Module combinations on Framework Laptop 16
    Daniel - Open Reply
    unfortunately the touchpad only fits in the middle.
    The transitions from touchpad to spacers are clearly visible and tactile edges.
    you can press both touchpad module and spacers. Doesn't feel firm.
    I miss an overlap between spacers and touchpad to accommodate this
    Marout Yasuo Sluijter-Borms - Open Reply
    Unfortunately, my spacers on the right and left of the touchpad are floating a bit. There is so much play that the touchpad has a noticeable edge, meaning the spacer and touchpad are not flush. I have gently tightened all of the screws underneath. Any idea how to fix this?
    de_fo - Resolved on Release Reply
    If the spacers don't seem to fit properly, check that you've tightened the underlying Mid Plate screws enough, particularly numbers 16 and 17.
    George Pearson - Resolved on Release Reply
    • Once all Input Modules are installed, close both Input Deck Latches to secure them in place.
    It is much harder to do this replacement
    Step 10 Remove the ventilation plate: It is very difficult to detach this. It seems to be stuck somewhere.
    Missing step before 17 ; Remove memory
    Step 17 Remove the CPU heatsink from the motherboard: It takes a great deal of effort to get it off.
    Step 18 Remove liquid metal from the CPU chip; the liquid metal is difficult to remove and comes off in chunks.
    Step 19 Remove the transparent protective tape from the CPU/motherboard; Remove the black sponge surrounding the CPU chip: The sponge is difficult to remove; it comes off in small pieces, leaving a lot of residue behind.
    Step 21 Remove the sponge and liquid metal from the CPU heatsink. Same difficulties as with the CPU.
    Step 28 Install the ventilation plate. It is very difficult; it does not seem to fit properly.
    The finish line: The laptop did not work after startup. Everything only started working again after a BIOS reset.
    The laptop is faster after the replacement, but it still runs hot.
    Bert Vermeulen - Open Reply
    It was much harder to replace the complete work
    Step 10 Remove the ventilation plate: It was very difficult to detach.
    Missing step before 16; Remove memory from CPU
    It might be worth mentioning, when installing the M2 SSD, if you didn't have one installed, you need to remove the blue film GENTLY! Underneath the blue film is a pasty gray matter which I accidentally scrapped up a bit. I was peeling the blue film off really gently too, from what I had read and still, I f**ked it up!
    Mike Laurel - Resolved on Release Reply
    don't forget to replace the expansion cards :) (Step 4)
    Leopold von Seckendorff - Resolved on Release Reply
    At this point or earlier, if you have both a graphics card and expansion bay in your order you might wonder what the L shaped extra part is and where it goes. My graphics module came installed and there was an L shaped interposer left in the box (labeled FRAKHNC PA1403200JM). That part is only used if you swap out the graphics card for the expansion bay, it's not needed if your graphics module is pre-installed.
    Hope - Resolved on Release Reply
Finish Line
15 other people completed this guide.
Sandy Qualey-Dobson
45 Guides authored
232 Guides authored
7 Comments
Here's a data point for estimated time to complete: I timed myself installing this graphics module from an expansion bay shell and it took about 12 minutes.
Baldwin Chang - Open Reply
I ran into a screen that said No Expansion Bay installed. I think I was too cautious tightening the interposer; I had to go back and redo that step. Maybe an additional 3-5 minutes spent doing that.
Baldwin Chang -
I love how beginner friendly this setup guide is, I don't know much about hardware specifics but this is the first time i've felt confident following the steps. I struggled a bit at step 15 because tightening the connectors in back (closer to the display) wouldn't budge if the other two connectors were tightened. I had to actively read the comment section on that step to make sure I wasn't doing anything wrong but noticed a lot of people had a similar issue. Nonethless, this was a smooth process that took around 20~ minutes to do, especially for someone who is kind of new to this! (my partner gifted me a graphics module for my birthday today, he's so thoughtful! I am insanely happy)
Maya Belmont - Open Reply
I think this was faster than installing a desktop GPU. No cable management to mess with. Pretty cool.
Coffey - Open Reply
I had the AMD Radeon RX 7700S Graphics Module installed, and I swapped it out for the new NVIDIA Graphics Module. It took me 11:29 total. This included taking out my existing Graphics Module, and unboxing the new NVIDIA Graphics Module.
Shawn Peters - Open Reply
Step 10 says "with the imposer installed." But it was removed, and a new one with 4 screwqs is installed in a later step. You need to point this out.
James Rome - Resolved on Release Reply
+1, this was also confusing for me, but I figured it out.
btw even with that confusion, Time Required was 8-10 minutes.
Max Aller -
Past 7 Days: 2
Past 30 Days: 5
All Time: 12,634
