Public Release - 1.04
by Iroh
Follow this guide to remove and replace the memory (aka RAM) in your Framework Laptop 16.
Your Framework Laptop has two DDR5 SO-DIMM sockets that supports up to 32 GB each of DDR5-5600 memory. If you install memory faster than the supported speed, the laptop will work properly, but not use the full memory speed.
No parts specified.
    • Remove the keyboard.
    • Remove the Input Module.
  11. Push the two metal arms on each side of the RAM stick outward until they disengage and the stick pops up at a shallow angle. Repeat for the other RAM stick. Repeat for the other RAM stick.
    • Push the two metal arms on each side of the RAM stick outward until they disengage and the stick pops up at a shallow angle.
    • Repeat for the other RAM stick.
  12. Slide the RAM stick out of its socket and remove it. Repeat for the other RAM stick. Repeat for the other RAM stick.
    • Slide the RAM stick out of its socket and remove it.
  13. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  14. Hold the memory module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils. Orient the module with its label facing down and align the gold contacts with the left socket labeled DDR5 Channel 0. Insert the contact edge into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • Orient the module with its label facing down and align the gold contacts with the left socket labeled DDR5 Channel 0.
    • Press the edges of the memory module down until the side clips lock it in place.
  15. If you're using two memory modules, orient the other module so its label is facing upward and repeat the previous step for the other socket labeled DDR5 Channel 1. If you're using two memory modules, orient the other module so its label is facing upward and repeat the previous step for the other socket labeled DDR5 Channel 1. If you're using two memory modules, orient the other module so its label is facing upward and repeat the previous step for the other socket labeled DDR5 Channel 1.
    • If you're using two memory modules, orient the other module so its label is facing upward and repeat the previous step for the other socket labeled DDR5 Channel 1.
  16. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
  17. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
  18. Align the Mid Plate cable press connector over its socket and press down to connect it. Align the Mid Plate cable press connector over its socket and press down to connect it.
  19. Your Input Module(s) might be different, but the procedure to remove them is the same. Align the top edge of the Input Module with the top edge of the laptop. Lay the Input Module on the laptop and let the magnets pull the keyboard into place
  20. Align the top edge of the keyboard with the top edge of the laptop. Lay the keyboard on the laptop and let the magnets pull the keyboard into place Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  21. Place the Touchpad Module flat on its cutout so its clips are properly aligned. Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  22. Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly. Slide the Touchpad Spacer towards the top of the laptop to secure it. Repeat the same procedure for the other Touchpad Spacer.
  23. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them.
After installing new memory, the laptop will take longer to start up for the first time, and the screen will turn on slower. This is normal—the system is performing memory training.
4 other people completed this guide.
Iroh
72 Guides authored
180 Guides authored
Past 24 Hours: 1
Past 7 Days: 27
Past 30 Days: 117
All Time: 1,909
