Asset Update
by Iroh
    • There are four alignment pins located on the Top Cover. They are located right next to the four fastener slots. Place the silver brackets connected to Display directly over the pins.
    • Be sure to only handle the Display by the side edges and avoid touching the bottom area.
  1. Using the T5 bit in the Framework Screwdriver screw the four fasteners into place. Be sure to not over tighten the fasteners.
    • Using the T5 bit in the Framework Screwdriver screw the four fasteners into place.
    • Be sure to not over tighten the fasteners.
Finish Line
Sandy Qualey-Dobson
45 Guides authored
225 Guides authored
Past 30 Days: 2
All Time: 62
