Asset Update
by Iroh
    • While handling the Battery with the plastic frame, slide it into the Bottom Cover. Use the first image as a reference.
  1. Before plugging the Battery connector back in, double check the pins on the Battery receptacle on the Mainboard, and make sure none of them look bent.
    • Before plugging the Battery connector back in, double check the pins on the Battery receptacle on the Mainboard, and make sure none of them look bent.
    • Don't plug the Battery connector in if pins look bent, as that will bend them even further. Reach out to Framework Support for guidance.
    • If you feel resistance when plugging in the Battery connector, stop, slide the connector back out, and make sure that no pins are being bent.
    • Carefully slide the Battery connector back into the Mainboard, gripping both edges of the connector and sliding in straight without letting the connector twist or bend.
    • Using the T5 bit in the Framework Screwdriver, screw the three fasteners into place.
    • The battery is now fully connected to the Framework Laptop.
Finish Line
Jehan Suleman
17 Guides authored
194 Guides authored
Past 7 Days: 1
Past 30 Days: 1
All Time: 38
