new and existing input cover guides created
by Sandy Qualey-Dobson
  1. Gently place the Input Cover keyboard side down on the Bottom Cover as indicated on the image. The cover should be about an inch and a half away from the bottom of the Mainboard so that you can comfortably install the Touchpad Cable. Note: The orientation of the Input Cover matters. Study the first image in this step to ensure you are properly attaching the cover. Locate the loop on the end of the Touchpad Cable and insert your finger into it.
    • Gently place the Input Cover keyboard side down on the Bottom Cover as indicated on the image. The cover should be about an inch and a half away from the bottom of the Mainboard so that you can comfortably install the Touchpad Cable.
    • Note: The orientation of the Input Cover matters. Study the first image in this step to ensure you are properly attaching the cover.
    • Locate the loop on the end of the Touchpad Cable and insert your finger into it.
    "While flipped over, the top edge of the cover should overlap the bottom edge of the Mainboard by about an inch and a half so..." I think this would be a better way to phrase it.
    Patrick Nolen - Open Reply
    It means that instead of "lining it up" to the bottom of the frame it needs to be overlapping (at least) 1,5 inch above the mainboard. Otherwise you will not be able to assemble the touchpad cable.
    5tephan - Resolved on Release Reply
    "The cover should be about an inch and a half away from the bottom of the Mainboard"... what does this mean?
    abc - Resolved on Release Reply
  2. Using slight force, connect the Touchpad Cable by aligning it to the socket on Mainboard. You should hear it click into place once properly connected. Using slight force, connect the Touchpad Cable by aligning it to the socket on Mainboard. You should hear it click into place once properly connected. Using slight force, connect the Touchpad Cable by aligning it to the socket on Mainboard. You should hear it click into place once properly connected.
    at best there is a very soft noise when fully inserted (?), certainly not a click
    Robert - Resolved on Release Reply
    Will it stay there when it's clicked into place? I've never done anything remotely like this before so I'm afraid I'm going to break something if I'm too rough with it.
    Courtney - Resolved on Release Reply
    Yes, it will stay pretty firmly.
    Keith -
Finish Line
Sandy Qualey-Dobson
47 Guides authored
194 Guides authored
One Comment
You guys need to hire an actual technical writer for these How-To guides before you get more customers like me - people who know nothing about computers but don't want to have to buy a whole new computer every time some part stops working or becomes obsolete. If only to review comments and make edits on the ones confusing multiple people.
Past 30 Days: 1
All Time: 45
