Public Release - 1.0
by Iroh
Follow this guide to remove and replace the Input Cover in your Framework Laptop 12.
The Input Cover (aka top cover or keyboard cover) is the piece that contains the keyboard and touchpad. You can easily remove the Input Cover and swap in one with a different keyboard layout or color.
No parts specified.
  3. Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop. Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
  4. Flip your laptop over so it's face-up on your work surface.
    • Flip your laptop over so it's face-up on your work surface.
  5. Open the laptop lid so that both the screen and the base lie flat on your work surface. Open the laptop lid so that both the screen and the base lie flat on your work surface.
  6. Use your fingers to grip the Input Cover in the hinge cutouts. Lift upwards to swing the Input Cover up from the base of the laptop. There are magnets holding the Input Cover down, so you'll feel some resistance. If it feels like a lot of force is required, check that you've fully loosened all the screws on the bottom of your laptop.
    • There are magnets holding the Input Cover down, so you'll feel some resistance. If it feels like a lot of force is required, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
  7. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  8. Angle the bottom edge of the Input Cover towards the base of the laptop. Align and insert the bottom edge of the Input Cover into the base of the laptop. Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Angle the bottom edge of the Input Cover towards the base of the laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the laptop.
  9. Close the laptop lid. Flip your laptop face-down on a clean work surface.
    • Close the laptop lid.
    • Flip your laptop face-down on a clean work surface.
  10. Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop. Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
Iroh
110 Guides authored
222 Guides authored
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,365
