Public Release - 1.01
by Iroh
Use this guide to replace the Input Cover in your Framework 13 Laptop Pro.
IMPORTANT: For Framework Laptop 13, please update to the latest BIOS before swapping to the Pro Input Cover to ensure full functionality of the Haptic Touchpad after booting.
No parts specified.
  2. Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover. Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover.
  3. Flip over your laptop and open it. Use your fingers to lift the Input Cover up and release it from its magnets.
    • Flip over your laptop and open it.
    • If you're having trouble lifting the Input Cover, you can leverage the gap at the bottom right corner to get your fingers fully under it.
  4. Flip the top of the Input Cover so the Keyboard is facing down. Rest the Input Cover over the Battery, making sure the Touchpad Cable isn't being strained.
    • Flip the top of the Input Cover so the Keyboard is facing down.
  5. Insert your finger into the Touchpad Cable press connector loop. Lift up to disconnect the Touchpad Cable from the Mainboard.
  6. Remove the Input Cover. Remove the Input Cover.
    • Remove the Input Cover.
  7. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  8. Position the Input Cover, Keyboard down, on top of the laptop so it just covers the Battery. This allows the Touchpad Cable to be folded over and reconnected without straining it.
    • Position the Input Cover, Keyboard down, on top of the laptop so it just covers the Battery.
  9. Insert your finger into the Touchpad Cable press connector loop. Align the press connector over its socket and press down with your finger.
    • You should hear it "click" into place. If you're having trouble, reposition it and try again. Don't try to force the connector into place.
  10. Flip the Input Cover over the laptop and align the bottom edges. Flip the Input Cover over the laptop and align the bottom edges.
    • Flip the Input Cover over the laptop and align the bottom edges.
  11. Lay the Input Cover over the laptop and let the magnets snap it into place. The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws. The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws.
    • The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws.
  12. Close the laptop and flip it over.
  13. Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover. Don't overtighten the screws—just make sure they're snug.
Iroh
112 Guides authored
238 Guides authored
Past 30 Days: 5
All Time: 25
