Public Release - 1.01
by Iroh
Follow this guide to remove and replace the heatsink in your Framework Laptop 12.
The Framework Heatsink comes with PTM7958 thermal compound pre-applied to it, so you don't need replacement thermal paste. You do need the cleaning supplies listed in the tools section to clean off the thermal compound residue from the processor.
  • The Input Cover is the part that contains the Keyboard and Touchpad.
No parts specified.
  1. Before you begin repairs, unplug your Laptop and shut it down from the operating system. This ensures that the Laptop isn't in standby/suspend mode. The indicator LEDs along the edges should be unlit. The Laptop should be silent. If you accidentally turn on the Laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Before you begin repairs, unplug your Laptop and shut it down from the operating system. This ensures that the Laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The Laptop should be silent.
    • If you accidentally turn on the Laptop during repair, hold the power button down for 10 seconds to shut it down.
  3. Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your Laptop. Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your Laptop.
    • Your Laptop comes with a spare set of screws in the frame above the battery. Be careful—the replacement screws aren't captive.
  4. Flip your Laptop over so it's face-up on your work surface.
    • Flip your Laptop over so it's face-up on your work surface.
  5. Open the Laptop lid so that both the screen and the base lie flat on your work surface. Open the Laptop lid so that both the screen and the base lie flat on your work surface.
    • Open the Laptop lid so that both the screen and the base lie flat on your work surface.
  6. Use your fingers to grip the Input Cover in the hinge cutouts. Lift upwards to swing the Input Cover up from the base of the Laptop. There are magnets holding the Input Cover down, so you'll feel some resistance. If it feels like a lot of force is required, check that you've fully loosened all the screws on the bottom of your Laptop.
    • Lift upwards to swing the Input Cover up from the base of the Laptop.
    • There are magnets holding the Input Cover down, so you'll feel some resistance. If it feels like a lot of force is required, check that you've fully loosened all the screws on the bottom of your Laptop.
    • Remove the Input Cover.
  7. Use your Framework Screwdriver to loosen the four captive Torx T5 screws securing the Heatsink.
    • Use your Framework Screwdriver to loosen the four captive Torx T5 screws securing the Heatsink.
  8. Slide the flat end of your Framework Screwdriver under the Heatsink arm labeled "2". Twist the Framework Screwdriver to lift the Heatsink arm and loosen the Heatsink. You'll feel some resistance from the thermal compound holding the Heatsink in place.
    • Slide the flat end of your Framework Screwdriver under the Heatsink arm labeled "2".
    • Twist the Framework Screwdriver to lift the Heatsink arm and loosen the Heatsink.
    • You'll feel some resistance from the thermal compound holding the Heatsink in place.
    • If the Heatsink won't budge, make sure you've fully loosened the four screws securing the Heatsink.
    • Repeat the procedure with the Heatsink arm labeled "3".
  9. Lift and remove the Heatsink. Lift and remove the Heatsink.
    • Lift and remove the Heatsink.
  10. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  11. Use a few drops of high concentration (>90%) isopropyl alcohol and a lint-free cloth to wipe away the remaining residue from the processor.
    • Use a few drops of high concentration (>90%) isopropyl alcohol and a lint-free cloth to wipe away the remaining residue from the processor.
  12. Unwrap the replacement Heatsink and remove the clear plastic cover. Be careful not to touch the gray thermal compound on the Heatsink.
    • Unwrap the replacement Heatsink and remove the clear plastic cover.
    • Be careful not to touch the gray thermal compound on the Heatsink.
  13. Carefully align and lay the Heatsink over the processor. Use your Framework Screwdriver to gradually tighten the Heatsink screws in the marked order until they're snug:
    • Carefully align and lay the Heatsink over the processor.
    • Use your Framework Screwdriver to gradually tighten the Heatsink screws in the marked order until they're snug:
    • First screw
    • Second screw
    • Third screw
    • Fourth screw, then back to the first
    • This helps compress the thermal compound evenly under the Heatsink and apply even pressure over the processor.
  14. Angle the bottom edge of the Input Cover towards the base of the Laptop. Align and insert the bottom edge of the Input Cover into the base of the Laptop. Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Angle the bottom edge of the Input Cover towards the base of the Laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the Laptop.
  15. Close the Laptop lid. Flip your Laptop face-down on a clean work surface.
    • Close the Laptop lid.
    • Flip your Laptop face-down on a clean work surface.
  16. Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your Laptop. Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
    • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your Laptop.
Iroh
112 Guides authored
227 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 68
