Public Release - 1.0
by Iroh
This guide shows how to install and remove the Tiles on your Framework Desktop.
The Tiles are mainly for decoration; they aren't necessary for your desktop to function.
The Front Panel can support up to 21 tiles.
  1. Use your fingers to pull the Front Panel off the magnets securing it to the chassis. Use your fingers to pull the Front Panel off the magnets securing it to the chassis. Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
    • Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
  2. Use your fingers to push the bottom of the Tile up and off the front panel and release its clips. Remove the Tile. Remove the Tile.
    • Use your fingers to push the bottom of the Tile up and off the front panel and release its clips.
    • Remove the Tile.
  3. Repeat this procedure for the remaining tiles. Repeat this procedure for the remaining tiles. Repeat this procedure for the remaining tiles.
    • Repeat this procedure for the remaining tiles.
  4. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
  5. Tiles can be installed in any orientation, even the ones with graphics. Lay a Tile over an open slot on your Front Panel. Use your fingers to press the tile into the slot and engage the clips.
    • Tiles can be installed in any orientation, even the ones with graphics.
    • Lay a Tile over an open slot on your Front Panel.
    • Use your fingers to press the tile into the slot and engage the clips.
    • You'll hear and feel an audible "click" when the clips engage.
  6. Install the remaining Tiles. Install the remaining Tiles. Install the remaining Tiles.
    • Install the remaining Tiles.
  7. Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs. Press the Front Panel flat to the chassis and let it align to the magnets. Press the Front Panel flat to the chassis and let it align to the magnets.
    • Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
    • Press the Front Panel flat to the chassis and let it align to the magnets.
Iroh
112 Guides authored
238 Guides authored
Past 30 Days: 0
All Time: 433
