Public Release - 1.0
by Iroh
Follow this guide to remove and replace the Fingerprint Reader in your Framework Laptop 12.
Check that you're using the latest Driver Bundle on Windows, or libfprint v1.94.100 or newer on Linux. Check out this page for Linux distro recommendations.
  • The Input Cover is the part that contains the Keyboard and Touchpad.
No parts specified.
  1. Before you begin repairs, unplug your Laptop and shut it down from the operating system. This ensures that the Laptop isn't in standby/suspend mode. The indicator LEDs along the edges should be unlit. The Laptop should be silent. If you accidentally turn on the Laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Before you begin repairs, unplug your Laptop and shut it down from the operating system. This ensures that the Laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The Laptop should be silent.
    • If you accidentally turn on the Laptop during repair, hold the power button down for 10 seconds to shut it down.
  3. Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your Laptop. Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your Laptop.
    • Your Laptop comes with a spare set of screws in the frame above the battery. Be careful—the replacement screws aren't captive.
  4. Flip your Laptop over so it's face-up on your work surface.
    • Flip your Laptop over so it's face-up on your work surface.
  5. Open the Laptop lid so that both the screen and the base lie flat on your work surface. Open the Laptop lid so that both the screen and the base lie flat on your work surface.
    • Open the Laptop lid so that both the screen and the base lie flat on your work surface.
  6. Use your fingers to grip the Input Cover in the hinge cutouts. Lift upwards to swing the Input Cover up from the base of the Laptop. There are magnets holding the Input Cover down, so you'll feel some resistance. If it feels like a lot of force is required, check that you've fully loosened all the screws on the bottom of your Laptop.
    • Lift upwards to swing the Input Cover up from the base of the Laptop.
    • There are magnets holding the Input Cover down, so you'll feel some resistance. If it feels like a lot of force is required, check that you've fully loosened all the screws on the bottom of your Laptop.
    • Remove the Input Cover.
  7. Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Fingerprint Reader.
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Fingerprint Reader.
  8. Use your fingers to lift and remove the Fingerprint Reader. Use your fingers to lift and remove the Fingerprint Reader. Use your fingers to lift and remove the Fingerprint Reader.
    • Use your fingers to lift and remove the Fingerprint Reader.
  9. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  10. Use your fingers to lay the Fingerprint Reader in place. Use the two plastic pins on the laptop to align the Fingerprint Reader. Use the two plastic pins on the laptop to align the Fingerprint Reader.
    • Use your fingers to lay the Fingerprint Reader in place.
    • Use the two plastic pins on the laptop to align the Fingerprint Reader.
  11. Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Fingerprint Reader.
    • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Fingerprint Reader.
    • Tighten the screw until it's snug. Don't over-tighten it, or you may strip the screw.
  12. Angle the bottom edge of the Input Cover towards the base of the Laptop. Align and insert the bottom edge of the Input Cover into the base of the Laptop. Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Angle the bottom edge of the Input Cover towards the base of the Laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the Laptop.
  13. Close the Laptop lid. Flip your Laptop face-down on a clean work surface.
    • Close the Laptop lid.
    • Flip your Laptop face-down on a clean work surface.
  14. Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your Laptop. Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
    • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your Laptop.
To ensure the Fingerprint Reader functions properly, make sure you're using the latest Driver Bundle on Windows, or at least libfprint v1.94.100 on Linux.
Iroh
112 Guides authored
11 Members
236 Guides authored
Past 30 Days: 0
All Time: 6
