Fedora 44 Workstation Framework 13 Pro v2.0
by Matt Hartley
Once you have your Framework Laptop 13 Pro set up following the Quick Start Guide, you’re ready to install your preferred OS. The Framework Laptop 13 is running some very recent hardware, and we’ve worked with the team at Fedora to improve support. Fedora 44 is one of the Linux distributions we recommend, as it has full hardware support with very little setup required, and it offers a great user experience overall.
Tools
No tools specified.
    • If upgrading from Fedora 43, we recommend backing up your home directory and doing a clean installation. If you decide you prefer to upgrade from 43, make absolutely sure your 43 installation is fully up to date first. Should you wish to instead, the DNF System Plugin method remains an option.
    • Current Upgrade Bugs - affected 43, may apply to 44: Additionally, there are some upgrade notes to be aware of. Systems with WINE installed cannot be updated and Systems with <=1 GB /boot partition may see “need more space” error during system update. See links for workarounds.
  2. First, download the latest Fedora release from the Fedora website. This guide will walk through installing Fedora by automatically using an entire disk. If upgrading from Fedora 43, we recommend backing up the home directory and doing a clean installation. To minimize risk when upgrading from 43, make absolutely sure everything is fully up to date first.
    • First, download the latest Fedora release from the Fedora website. This guide will walk through installing Fedora by automatically using an entire disk.
    • If upgrading from Fedora 43, we recommend backing up the home directory and doing a clean installation. To minimize risk when upgrading from 43, make absolutely sure everything is fully up to date first.
    • Current Upgrade Bugs: Additionally, there are some upgrade notes to be aware of. Systems with WINE installed cannot be updated and Systems with <=1 GB /boot partition may see “need more space” error during system update. See links for workarounds. Clean installs will be the easiest path for some.
    • Download Rufus as a tool to create the USB installer from the ISO. The first item in this list will be a link to install installer for the latest version. Install Rufus using this. Open Rufus, from the Device drop-down, select the USB flash drive stick.
    • Use the Select Button next to Boot selection to choose the downloaded Fedora ISO.
  3. First, download the latest Fedora Workstation release https://fedoraproject.org/workstation/ from the Fedora website. This Guide assumes a simple installation scenario of a fresh install on a blank drive. Fedora: Media Writer is already installed on Workstation, so just launch it from the app menu. Other distro, Flatpak installed: Run flatpak install flathub org.fedoraproject.MediaWriter, then launch it from the app menu or with flatpak run org.fedoraproject.MediaWriter.
    • First, download the latest Fedora Workstation release https://fedoraproject.org/workstation/ from the Fedora website. This Guide assumes a simple installation scenario of a fresh install on a blank drive.
    • Fedora: Media Writer is already installed on Workstation, so just launch it from the app menu.
    • Other distro, Flatpak installed: Run flatpak install flathub org.fedoraproject.MediaWriter, then launch it from the app menu or with flatpak run org.fedoraproject.MediaWriter.
    • Other distro, no Flatpak: Install Flatpak and add Flathub per https://flathub.org/setup
    • Insert an 8 GB+ USB key. Back up its contents first, since this erases the entire drive.
    • Open Fedora Media Writer, choose Select .iso file, and pick the Fedora 44 Workstation ISO you downloaded.
    • Select your USB drive from the device list, double-checking the name and size so you don't wipe the wrong disk.
    • Click Write, enter your password if prompted, wait for it to finish, then click Finish and safely eject the USB.
  4. Fedora works with Secure Boot out of the box. Fedora Live USBs will boot regardless of whether or not it is disabled. Users who intend to dual-boot with Windows should not disable Secure Boot! If a user has a reason to disable Secure Boot, such as specialized third party devices that require unsigned drivers: Boot into BIOS by tapping F2 just before the Framework splash screen.
    • Fedora works with Secure Boot out of the box. Fedora Live USBs will boot regardless of whether or not it is disabled. Users who intend to dual-boot with Windows should not disable Secure Boot!
  5. Boot to Fedora Live USB: Insert the USB drive into the powered-off machine, then power it on.
    • Boot to Fedora Live USB: Insert the USB drive into the powered-off machine, then power it on.
    • If Windows is currently installed, trying to boot a Linux Live USB can result in the "Device is Active" error. This will provide guidance to overcome this error.
    • Next select Start Fedora Workstation-Live 44. Hit the enter key.
    • The installer will start automatically after some time. How long depends on the speed of the USB drive.
  6. Select the keyboard language you'd like to use.  On the next screen, click on the Installation Destination button to choose the disk.  Note that you can install Fedora onto a USB drive or a Storage Expansion Card as an alternative to installing it onto your internal drive. If there is an OS already installed on the target drive, you'll need to follow the guided steps in the installer to resize partitions or delete the existing partitions.  This is out of scope of this guide, but Fedora has very detailed documentation: https://docs.fedoraproject.org/en-US/qui...
  7. Click on preferred language, again for your preferred keyboard. This begins the process of completing the initial setup of your Fedora installation. Connect to Wi-Fi or Skip. If you wish not to connect to wireless just yet, you can skip this and return to connecting to Wi-Fi later on. Choose your Privacy settings. Here you can decide if you would like to allow Location Services using Mozilla Location Service or not.
  8. To configure the touchpad to meet your needs:
  9. Let's setup fingerprint login. Click on Activities, search for user. Choose Fingerprint Login. Then select Scan new fingerprint. Select your desired fingerprint. Carefully tap your finger tip on the sensor (power button). You may need to try a few attempts as everyone's prints are different.
    • Let's setup fingerprint login. Click on Activities, search for user.
    • We're almost done. Please follow the links to your Framework Laptop 13 Pro.
    • Click here for the completion guide for Framework Laptop 13 Pro.
    • How to check the BIOS version. Go to and click upper left corner where you see the horizontal line, search terminal and launch it. Please follow this link to copy and paste the code into your terminal, then press enter. The output will tell you which Framework Laptop 13 Pro you have and also which BIOS version you're using.
    • If you have Intel Core Ultra Series 3, you can check (Coming soon) for the latest firmware.
Enjoy using Fedora on your Framework Laptop 13 Pro!
Matt Hartley
40 Guides authored
227 Guides authored
Past 30 Days: 11
All Time: 61
