Fedora 44 Framework Laptop 13 Pro v1.03
by Matt Hartley
Once you have your Framework Laptop 13 Pro set up following the Quick Start Guide, you’re ready to install your preferred OS. The Framework Laptop 13 is running some very recent hardware, and we’ve worked with the team at Fedora to improve support. Fedora 44 is one of the Linux distributions we recommend, as it has full hardware support with very little setup required, and it offers a great user experience overall.
Tools
No tools specified.
    • If upgrading from Fedora 43, we recommend backing up your home directory and doing a clean installation. If you decide you prefer to upgrade from 43, make absolutely sure your 43 installation is fully up to date first. Should you wish to instead, the DNF System Plugin method remains an option.
    • Current Upgrade Bugs - affected 43, may apply to 44: Additionally, there are some upgrade notes to be aware of. Systems with WINE installed cannot be updated and Systems with <=1 GB /boot partition may see “need more space” error during system update. See links for workarounds.
  2. First, download the latest Fedora release from the Fedora website. We'll go through the steps in this Guide assuming you have a simple installation scenario of a fresh install on a blank drive. Download Rufus as a tool to create the USB installer from the ISO - select the top download option from the link provided. Rufus is available for Windows. Install it.
    • Current Upgrade Bugs: Additionally, there are some upgrade notes to be aware of. Systems with WINE installed cannot be updated and Systems with <=1 GB /boot partition may see “need more space” error during system update. See links for workarounds. Clean installs will be the easiest path for some.
    • Open Rufus, from the Device drop-down, select your USB flash drive stick.
    • Use the "Select" Button next to "Boot Selection" to choose the downloaded Linux ISO
    • Set "Partition Scheme" to "GPT".
    • Click Start, then click OK with the default dialog of "ISOHybrid image mode"
  3. Secure Boot is optional on Fedora: Enabling secure boot is completely optional and not necessary for normal operation, it's a personal choice - but there are trade offs to be aware of. Follow this link if you wish to enable it before installing Fedora. More about secure boot here. You will find Fedora specific instructions here. If you have decided to disable secure boot. You will do so by booting into the BIOS menu: Power on, then tap F2 rapidly at the Framework splash screen
    • Secure Boot is optional on Fedora: Enabling secure boot is completely optional and not necessary for normal operation, it's a personal choice - but there are trade offs to be aware of. Follow this link if you wish to enable it before installing Fedora. More about secure boot here. You will find Fedora specific instructions here.
  4. Once you have reviewed the previous step, continue
    • Insert the USB drive into your powered off Framework Laptop 13, and then power on. If you have an existing OS installed on the Storage drive in your laptop, immediately after the power light comes on begin rapidly tapping (continuously ) the F12 key - you must begin tapping well before you see the Framework logo.
    • Select the USB drive. Press the enter key.
    • Next select Start Fedora Workstation-Live 44. Hit the enter key.
    • After a few seconds, you're in! If you just want to try Fedora out, you can click on the Try Fedora button and browse through the live USB version of it without touching the internal storage drive. If you do want to install Fedora to the internal storage drive, go on to the next step.
  5. Select the keyboard language you'd like to use.  On the next screen, click on the Installation Destination button to choose the disk.  Note that you can install Fedora onto a USB drive or a Storage Expansion Card as an alternative to installing it onto your internal drive. If there is an OS already installed on the target drive, you'll need to follow the guided steps in the installer to resize partitions or delete the existing partitions.  This is out of scope of this guide, but Fedora has very detailed documentation: https://docs.fedoraproject.org/en-US/qui...
  6. Click on preferred language, again for your preferred keyboard. This begins the process of completing the initial setup of your Fedora installation. Connect to Wi-Fi or Skip. If you wish not to connect to wireless just yet, you can skip this and return to connecting to Wi-Fi later on. Choose your Privacy settings. Here you can decide if you would like to allow Location Services using Mozilla Location Service or not.
  7. To configure the touchpad to meet your needs:
  8. Let's setup fingerprint login. Click on Activities, search for user. Choose Fingerprint Login. Then select Scan new fingerprint. Select your desired fingerprint. Carefully tap your finger tip on the sensor (power button). You may need to try a few attempts as everyone's prints are different.
    • Let's setup fingerprint login. Click on Activities, search for user.
    • We're almost done. Please follow the links to your Framework Laptop 13 Pro.
    • Click here for the completion guide for Framework Laptop 13 Pro.
    • Go to and click upper left corner where you see the horizontal line, search terminal and launch it. Please follow this link to copy and paste the code into your terminal, then press enter.
    • If you have Intel Core Ultra Series 3, you can check (Coming soon) for the latest firmware.
Enjoy using Fedora on your Framework Laptop 13 Pro!
Matt Hartley
41 Guides authored
223 Guides authored
Past 30 Days: 4
All Time: 19
