Public Release - 1.01
by Iroh
This guide shows how to replace or clean the fan in your Framework Laptop 12.
The fan helps keep your Framework Laptop cool and operating at full speed. Over time, the fan can get clogged and stop working. This guide will show how to clean out the fan to restore your Laptop functionality.
  • The Input Cover is the part that contains the Keyboard and Touchpad.
No parts specified.
  1. Before you begin repairs, unplug your Laptop and shut it down from the operating system. This ensures that the Laptop isn't in standby/suspend mode. The indicator LEDs along the edges should be unlit. The Laptop should be silent. If you accidentally turn on the Laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Before you begin repairs, unplug your Laptop and shut it down from the operating system. This ensures that the Laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The Laptop should be silent.
    • If you accidentally turn on the Laptop during repair, hold the power button down for 10 seconds to shut it down.
  3. Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your Laptop. Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your Laptop.
    • Your Laptop comes with a spare set of screws in the frame above the battery. Be careful—the replacement screws aren't captive.
  4. Flip your Laptop over so it's face-up on your work surface.
    • Flip your Laptop over so it's face-up on your work surface.
  5. Open the Laptop lid so that both the screen and the base lie flat on your work surface. Open the Laptop lid so that both the screen and the base lie flat on your work surface.
    • Open the Laptop lid so that both the screen and the base lie flat on your work surface.
  6. Use your fingers to grip the Input Cover in the hinge cutouts. Lift upwards to swing the Input Cover up from the base of the Laptop. There are magnets holding the Input Cover down, so you'll feel some resistance. If it feels like a lot of force is required, check that you've fully loosened all the screws on the bottom of your Laptop.
    • Lift upwards to swing the Input Cover up from the base of the Laptop.
    • There are magnets holding the Input Cover down, so you'll feel some resistance. If it feels like a lot of force is required, check that you've fully loosened all the screws on the bottom of your Laptop.
    • Remove the Input Cover.
  7. Use the flat end of your Framework Screwdriver to gently push on one of the fan connector's protruding edges, then the other, to loosen the connector out of its socket. Use the flat end of your Framework Screwdriver to gently push on one of the fan connector's protruding edges, then the other, to loosen the connector out of its socket. Use the flat end of your Framework Screwdriver to gently push on one of the fan connector's protruding edges, then the other, to loosen the connector out of its socket.
    • Use the flat end of your Framework Screwdriver to gently push on one of the fan connector's protruding edges, then the other, to loosen the connector out of its socket.
  8. Use your fingers and your Framework Screwdriver to slide the fan connector out of its socket. Use your fingers and your Framework Screwdriver to slide the fan connector out of its socket.
    • Use your fingers and your Framework Screwdriver to slide the fan connector out of its socket.
  9. Use your Framework Screwdriver to loosen the two captive T5 Torx screws securing the fan.
    • Use your Framework Screwdriver to loosen the two captive T5 Torx screws securing the fan.
  10. Lift and remove the fan. Lift and remove the fan.
    • Lift and remove the fan.
  11. If your fan's dirty, this is a great opportunity to clean it! A clean fan will help your laptop stay cooler. Use a soft bristled brush or a clean toothbrush to gently scrub the fan blades and exhaust fins.
    • If your fan's dirty, this is a great opportunity to clean it! A clean fan will help your laptop stay cooler.
    • Use a soft bristled brush or a clean toothbrush to gently scrub the fan blades and exhaust fins.
    • Use a dust blower to blow away the dust from the fan.
  12. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  13. Lay the fan in the laptop.
    • Lay the fan in the laptop.
  14. Use your Framework Screwdriver to tighten the two captive T5 Torx screws to secure the fan.
    • Use your Framework Screwdriver to tighten the two captive T5 Torx screws to secure the fan.
  15. Use your fingers to gently push the fan connector back into its socket. Don't push too hard, or you may break the socket. If you're having trouble, wiggle the connector slightly to help it slide into the socket.
    • Use your fingers to gently push the fan connector back into its socket.
    • Don't push too hard, or you may break the socket. If you're having trouble, wiggle the connector slightly to help it slide into the socket.
  16. Angle the bottom edge of the Input Cover towards the base of the Laptop. Align and insert the bottom edge of the Input Cover into the base of the Laptop. Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Angle the bottom edge of the Input Cover towards the base of the Laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the Laptop.
  17. Close the Laptop lid. Flip your Laptop face-down on a clean work surface.
    • Close the Laptop lid.
    • Flip your Laptop face-down on a clean work surface.
  18. Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your Laptop. Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
    • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your Laptop.
Iroh
112 Guides authored
238 Guides authored
Past 30 Days: 0
All Time: 104
