FL13 Display - Changing to all pre-req steps
by Iroh
  2. Disconnect the Touchpad Cable from the Mainboard by inserting your finger into the loop and pull directly upward using a slight amount of force. Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard. The Input Cover is now fully disconnected from the Bottom Cover.
    • Disconnect the Touchpad Cable from the Mainboard by inserting your finger into the loop and pull directly upward using a slight amount of force.
    • Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard.
    • The Input Cover is now fully disconnected from the Bottom Cover.
    • Open the Framework Laptop 180 degrees to remove the Bezel.
    • The Framework Bezel is attached by magnets so you will not require any tools to remove it. Just use your fingernail and pry the Bezel away from the display from one of the top corners of the Framework Laptop.
    • Once the Bezel starts peeling off towards the bottom of the Display, lift it up using caution. You might feel a little resistance due to the adhesive at the bottom of the display.
  3. Find the black Display Cable that connects the display to the mainboard. Unplug the cable by pulling it directly upwards using the black pull tab. Carefully lift up the silver grounding tape that is holding the Display Cable to the hinge.
    • Find the black Display Cable that connects the display to the mainboard. Unplug the cable by pulling it directly upwards using the black pull tab.
    • Carefully lift up the silver grounding tape that is holding the Display Cable to the hinge.
    • Free the Display Cable from the Bottom Cover and carefully remove it from any routing pegs. It will remain connected to the display.
    • Using the T5 bit in the Framework Screwdriver, unscrew the 4 fasteners connecting the Display to the Top Cover.
    • The Display is now fully unattached to the Top Cover, you can gently lift it up from the corner using your fingernail.
    • Be sure to only handle the Display by the side edges and avoid touching the bottom area.
    • There are four alignment pins located on the Top Cover. They are located right next to the four fastener slots. Place the silver brackets connected to Display directly over the pins.
  4. Using the T5 bit in the Framework Screwdriver screw the four fasteners into place. Be sure to not over tighten the fasteners.
    • Using the T5 bit in the Framework Screwdriver screw the four fasteners into place.
    • Be sure to not over tighten the fasteners.
    • Route the black Display Cable through the routing channel as indicated in the picture.
    • Secure the silver grounding tape as indicated in the first image.
    • Using the black pull tab, align the Display Cable connector with the connection on the Mainboard and firmly press down.
    • The Display installation is now complete.
  5. If installing a new Bezel, remove the liner pieces on the bottom of the Bezel to expose the adhesive (if present).
    • If installing a new Bezel, remove the liner pieces on the bottom of the Bezel to expose the adhesive (if present).
    • Open the Framework Laptop 180 degrees to attach the Bezel.
    • Starting with the bottom of the Bezel which covers the hinges and cables, align the corners of the Bezel to the display and place it down. The Bezel is attached by magnets and should easily click into place.
    • We recommend feeling along each edge of the Bezel to make sure it is seated correctly before proceeding, if it doesn't seem to be sitting flush, lift it back up and try lowering it into place again.
    • Do not try to install the Bezel without first opening the Laptop fully, doing so could damage the Bezel and potentially the Display.
    • If the bottom of the Bezel doesn't seem to fit, lift it back off and check that the cables are seated correctly on both sides. If the Bezel doesn't seem to fit at all, please contact support and do not force it into place.
    • Gently place the Input Cover keyboard side down on the Bottom Cover as indicated on the image. The cover should be about an inch and a half away from the bottom of the Mainboard so that you can comfortably install the Touchpad Cable.
    • Note: The orientation of the Input Cover matters. Study the first image in this step to ensure you are properly attaching the cover.
    • Locate the loop on the end of the Touchpad Cable and insert your finger into it.
  6. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
    • Close the Framework Laptop and place it upside down to reveal the fasteners on the Bottom Cover.
40 other people completed this guide.
Jehan Suleman
17 Guides authored
192 Guides authored
19 Comments
Quick reminder to those upgrading from the base display and also using GNOME, if you had enabled experimental fractional scaling so you can choose something like 150% scaling, I highly recommend removing that experimental feature. With it removed and on 200% scaling everything becomes super crisp. Even legacy windowing (x11) apps like Spotify, Slack, and whatnot look much better.
How to reset experimental fractional scaling is below. Note, you may want to fetch your experimental settings first in case you have any others you'd like to keep.
# enable fractional scaling
gsettings set org.gnome.mutter experimental-features "['scale-monitor-framebuffer']"
# fetch experimental features
gsettings get org.gnome.mutter experimental-features
# reset experimental features i.e. disable fractional scaling
gsettings reset org.gnome.mutter experimental-features
After that simply log out, log back in, and enjoy maximum crisp. 😁
Nicholas La Roux - Open Reply
Also recommend setting variable refresh rate experimental feature so that you're not burning through battery running at 120hz all the time. Can do so with the following command, which will give you variable refresh between 30hz and 120hz. :)
gsettings set org.gnome.mutter experimental-features "['variable-refresh-rate']"
Nicholas La Roux -
Is there a recommended way or place to recycle the old screen?
Aaron Wilson - Resolved on Release Reply
Is there a way to recycle the old screen or recommended vendor?
Hey I have a question: is a new Bezel needed when replacing the screen or can I reapply the old one without problems? Just asking because of the adhesive. Does anyone have a recommendation?
Martin Klejewski - Resolved on Release Reply
Past 24 Hours: 18
Past 7 Days: 117
Past 30 Days: 635
All Time: 38,269
