Disconnect the Touchpad Cable
by Iroh
  1. Disconnect the Touchpad Cable from the Mainboard by inserting your finger into the loop and pull directly upward using a slight amount of force. Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard. The Input Cover is now fully disconnected from the Bottom Cover.
    • Disconnect the Touchpad Cable from the Mainboard by inserting your finger into the loop and pull directly upward using a slight amount of force.
    • Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard.
    • The Input Cover is now fully disconnected from the Bottom Cover.
Finish Line
Iroh
110 Guides authored
225 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 53
