Asset Update
by Iroh
    • Disconnect the Touchpad Cable from the Mainboard by inserting your finger into the loop and pull directly upward using a slight amount of force.
    • Avoid disconnecting the Touchpad side of the cable unless you need to replace the Touchpad Cable itself, since that connector is more fragile.
    • Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard.
    • The Input Cover is now fully disconnected from the Bottom Cover and can be set aside.
Finish Line
Sandy Qualey-Dobson
45 Guides authored
238 Guides authored
Past 30 Days: 1
All Time: 95
