Introduction Update
by Iroh
How you handle the Framework Laptop battery matters. Remember to always handle the battery by the plastic frame, to not bend, scratch, cut, or puncture it, and to keep it away from heat sources.
We want to work with you to minimize the environmental impact of the Framework Laptop. When it’s time for a replacement, make sure you recycle your old battery appropriately. Visit Call2Recycle to find a drop off location near you.
Important Note: Before using a 61Wh Battery, make sure you are using the latest BIOS for your device.
    • Disconnect the Touchpad Cable from the Mainboard by inserting your finger into the loop and pull directly upward using a slight amount of force.
    • Avoid disconnecting the Touchpad side of the cable unless you need to replace the Touchpad Cable itself, since that connector is more fragile.
    • Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard.
    • The Input Cover is now fully disconnected from the Bottom Cover and can be set aside.
    • Be extremely careful when sliding the Battery connector out, as it is very easy to accidently bend the pins. Make sure to slide straight down, and avoid letting the connector twist or bend.
    • Gently disconnect the Battery by gripping the connector edges with both fingers and slide the connector straight down from the socket.
    • Using the T5 bit in the Framework Screwdriver, unscrew the three fasteners on the battery.
    • Note: The screws will come loose after a few revolutions however they will remain attached to the battery.
    • Use your finger tips to gently lift the battery up and away from the bottom cover. Carefully lift it out and keep it in a safe place.
    • Warning: Handle the battery by the plastic frame, make sure not to bend, scratch, cut, or puncture it, and keep it away from heat sources
    • While handling the Battery with the plastic frame, slide it into the Bottom Cover. Use the first image as a reference.
  2. Before plugging the Battery connector back in, double check the pins on the Battery receptacle on the Mainboard, and make sure none of them look bent.
    • Before plugging the Battery connector back in, double check the pins on the Battery receptacle on the Mainboard, and make sure none of them look bent.
    • Don't plug the Battery connector in if pins look bent, as that will bend them even further. Reach out to Framework Support for guidance.
    • If you feel resistance when plugging in the Battery connector, stop, slide the connector back out, and make sure that no pins are being bent.
    • Carefully slide the Battery connector back into the Mainboard, gripping both edges of the connector and sliding in straight without letting the connector twist or bend.
    • Using the T5 bit in the Framework Screwdriver, screw the three fasteners into place.
    • The battery is now fully connected to the Framework Laptop.
    • Gently place the Input Cover keyboard side down on the Bottom Cover as indicated on the image. The cover should be about an inch and a half away from the bottom of the Mainboard so that you can comfortably install the Touchpad Cable.
    • Note: The orientation of the Input Cover matters. Study the first image in this step to ensure you are properly attaching the cover.
    • Locate the loop on the end of the Touchpad Cable and insert your finger into it.
  3. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
    • Close the Framework Laptop and place it upside down to reveal the fasteners on the Bottom Cover.
  4. Batteries arrive in "shipping mode", where they will not power on until after AC power is plugged into the laptop. Plug the USB-C cable for power into the Framework Laptop.
    • Batteries arrive in "shipping mode", where they will not power on until after AC power is plugged into the laptop.
    • Plug the USB-C cable for power into the Framework Laptop.
    • Press the power button to boot up with your new battery!
    • Be sure to re-use or recycle your old battery safely, making sure to store it in a location where it won't be exposed to heat or handling in the meantime.
19 other people completed this guide.
Sandy Qualey-Dobson
45 Guides authored
222 Guides authored
5 Comments
Step 6 was extremely difficult for me, a medium-large dude with I guess proportionally large fingers trying to remove a spicy pillow puffy battery while waiting for the (permanently?) on back-order replacement battery.
Ended up having to use a small flathead screwdriver to VERY gently tap and pry out the connector. There was no way in heck that I can get enough purchase with my nails on the edges of that overly tight connector to get it out of there. I'm sure some engineer will tell me that they can't make the edges of the connector bigger because then people would use too much force to remove it, but that leaves me not able to get the darn thing out without using a tool, which defeats the purpose, no?
75338 - Open Reply
Hey, I used plastic levers similar to the back of a Framework screwdriver.
I think I saw your post on Reddit I think everyone got a Framework screwdriver like that.
Here is the link: https://frame.work/de/de/products/framew...
Ian Thomas -
For a company that makes modular laptops you guys don't make guides that are user friendly. I rather have a full video showing the whole process from start to finish instead of reading and opening images in another tap and back and forth.
azerx - Resolved on Release Reply
Wish newer framework laptops ship with removable/hot swappable batteries instead of it being built and screwed in to the laptop. That way, it would allow for easy battery replacements, plus allows user to own and maintain multiple batteries (and charge some externally with an external battery charging pack), which can also be sold in framework marketplace as an accessory whivh user can buy apart from replacable/hot-swappable batteries.
Saran Ayyappan - Resolved on Release Reply
You should sell “Battery connector” parts in the framework marketplace for those people that can solder the replacement connector to motherboard once pins get damaged.
Mikko Rantalainen - Resolved on Release Reply
Past 30 Days: 6
All Time: 35,192
