Public Release - 1.0
by Iroh
Follow this guide to replace the primary storage in your Framework Desktop.
Your Framework Desktop uses SSDs (Solid State Drive) for primary storage. The Desktop supports M.2 2280 NVMe SSDs in the primary storage's PCIe 4.0 socket.
For information on SSD compatibility, click here.
No parts specified.
    • Remove the Handle.
    • Remove the Top Panel screw.
  7. Use your fingers to grip the top of the Left Panel and slide it upward to release its clips. Remove the Left Panel. Remove the Left Panel.
    • Remove the Left Panel.
  8. Use your Framework Desktop Screwdriver to loosen the captive T5 Torx screw securing the SSD. The SSD and its heat spreader will pop up to an angle when its screw is fully loosened.
    • Use your Framework Desktop Screwdriver to loosen the captive T5 Torx screw securing the SSD.
    • The SSD and its heat spreader will pop up to an angle when its screw is fully loosened.
  9. While holding the heat spreader upright, grab the SSD by its edges and pull it out of its socket. Remove the SSD. Remove the SSD.
    • While holding the heat spreader upright, grab the SSD by its edges and pull it out of its socket.
    • Remove the SSD.
  10. If your replacement SSD comes with a pre-installed heat spreader, follow the next two steps. Otherwise skip this and the following step. While securing the primary storage heat spreader with one hand, use your Framework Desktop Screwdriver to remove the 4.5 mm‑long T5 Torx screw securing it. While securing the primary storage heat spreader with one hand, use your Framework Desktop Screwdriver to remove the 4.5 mm‑long T5 Torx screw securing it.
    • If your replacement SSD comes with a pre-installed heat spreader, follow the next two steps. Otherwise skip this and the following step.
    • While securing the primary storage heat spreader with one hand, use your Framework Desktop Screwdriver to remove the 4.5 mm‑long T5 Torx screw securing it.
  11. Lift the primary storage heat spreader out of the Desktop and remove it.
    • Lift the primary storage heat spreader out of the Desktop and remove it.
    • Follow the guide normally, making sure to ignore instructions that involve the primary storage heat spreader.
  12. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
  13. Use your Framework Desktop Screwdriver to loosen the captive T5 Torx screw securing the SSD.
  14. Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils. While holding the heat spreader upright, align the SSD's gold contacts with its socket.
    • While holding the heat spreader upright, align the SSD's gold contacts with its socket.
  15. Insert your Framework Desktop Screwdriver into the captive screw on the primary storage heat spreader and press it flat to the Mainboard. Tighten the screw securing the SSD. Tighten the screw securing the SSD.
    • Insert your Framework Desktop Screwdriver into the captive screw on the primary storage heat spreader and press it flat to the Mainboard.
    • Tighten the screw securing the SSD.
  16. Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place. There should be a small gap between the bottom of the Left Panel and the silver base. Push the Left Panel towards the base of the computer to close the gap and engage the clips.
  17. Orient the Top Panel so its arrow is pointing towards the rear of the computer. While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch. There should be a small gap between the Top Panel and the front of the Desktop.
  18. While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips. While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
  19. If you're installing the Handle on your Desktop, follow this step. Otherwise, skip it. Place the Handle over the Top Panel screw holes.
  20. Insert the top panel screw into its hole and twist clockwise until it feels snug. Insert the top panel screw into its hole and twist clockwise until it feels snug. Insert the top panel screw into its hole and twist clockwise until it feels snug.
  21. Repeat the same procedure for the other top panel screw. Repeat the same procedure for the other top panel screw. Repeat the same procedure for the other top panel screw.
  22. Use your finger to close the two D-rings on the top panel screws. Use your finger to close the two D-rings on the top panel screws. Use your finger to close the two D-rings on the top panel screws.
You finished fixing your Framework Desktop!
Iroh
88 Guides authored
194 Guides authored
One Comment
I don't understand if I should remove the "protective film" from the ssd storage heat spreader? No one mentions it, but it looks smooth like film (not sticky at all). If I try to remove "this film" it peels off and does not come off like a film.
Dmtirii - Open Reply
Past 24 Hours: 7
Past 7 Days: 24
Past 30 Days: 128
All Time: 1,826
